Хроники ИвоЛогоса
EvoLogos
Re: Как дела у Романтика?
Unread post by EvoLogos »
S1908 wrote: Fri Aug 17, 2018 6:47 pm а где можно найти эти упражнения 1-4?
То о чем я написал выше, это и есть краткое описание упражнений 1-4.
Более подробно, можно почитать англоязычные форумы, по запросу 'John Chang' и 'Mo Pai'.
Или книгу ученика Джона Чанга - Коста Данаос. Маг с Явы, 2000 год (Kosta Danaos. The Magus of Java).
Или книгу, пока еще не переведенную с английского языка - Jim McMillan. Seeking the Master of Mo Pai: Adventures with John Chang, 2011 год.
Вот небольшой фрагмент объяснений от Джима:
"In Mo Pai training you must develop 81 hours of total "concentration" to attain "certain" markers to show you’ve reached a specific level. So, it doesn’t matter how focused you are, it will still take a long time to attain this amount of concentration…so you need to be very patient and understand that you "concentrate" during meditation. I will know where you stand by the signs you will eventually attain. You need to tell me when they happen as well. I will give you a clue, it took me around fifteen months to achieve the "heat" in my dan tien. This is the first sign that your chi development is going along perfectly. The heat will also increase in its intensity to the point you might feel you are going to burn up…you will not, it is the chi throughout your body accumulating in your dan tien. Some people will gain this later and some sooner, don’t be discouraged, as it will come no matter what. The next feeling will most certainly come as did the fist; everyone gets it, but the only difference is it reacts differently on everyone; it is the same thing for everyone but affects different parts of your body. It is a wonderful confirmation of your development, as well as a surprising one; you will enjoy it!
Перевод:
В Мо Пай тренировке, вы должны всего произвести 81 час тотальной "концентрации" чтобы достигнуть "точные" признаки того, что вы достигли определенного уровня. Не важно как сфокусированы вы, это займет длительное время достигнуть этого количества концентрации, так что вы должны быть очень терпеливы и понимать над чем вы "концентрируетесь" во время медитации. Я пойму чего вы достигли, через знаки, которые вы в конечном счете получите. Я дам вам подсказку, это заняло у меня пятнадцать месяцев достигнуть "тепла-жжения" в моем даньтяне. Это первый знак что ваша энергия Ци работает отменно. Жжение также усилится в своей интенсивности до степени, что вы можете почувствовать что вы просто сгораете... но это не так, это энергия Ци внутри вашего тела аккумулируется в вашем даньтяне. Некоторые люди ощутят это раньше, а некоторые позднее, не волнуйтесь, так как вы этого достигните в любом случае.
Отрывок из книги Джима:
There are four stages or levels in nai gong in which the chi must go through in order for practitioners to “fuse both the yin and yang” (which is the main goal) in order to produce the abilities they seek. For the first of the four levels of nai gong: a practitioner must do meditation to “accumulate” yang chi in his dan tien. While this is occurring there is also accumulating an equal amount of yin in the perineum as well; the second level: this is a continuation of the first level still doing meditation, as there is still not enough yang energy accumulated, and at this level there is added physical, sort of muscle tension/isometric exercise. And when this is completed, you will be at the highest level of yang development. At this time the yang will become entirely compressed into the dan tien; the third level: the chi then has to be untwined, and the dan tien needs to be cut from the cords that hold it in place to be readied for the next level; and lastly the fourth level: the two energies need to be combined.
McMillan, Jim - Seeking the Master of Mo Pai (p. 72)
Перевод:
В нейгун существует четыре стадии или уровня, через которые энергия Ци должна пройти с целью для практиков "сплавить обе инь и ян" (что является главной целью), для того чтобы получить способности, которые они хотят. Для первого из четырех уровней нейгуна: практик должен медитировать чтобы "аккумулировать" ян Ци в его даньтяне. Пока длится этот процесс, также аккумулируется равное количество инь Ци в промежности. Второй уровень: он является продолжением первого уровня, где продолжается медитация, так как у практика все еще не достаточно ян энергии аккумулированной, и в этом уровне добавляется физическое, мышечное напряжение/изометрические упражнения. И когда это выполнено, вы будете на самом высоком уровне ян аккумуляции. В это время ян станет полностью сжатой внутри дяньтяня. Третий уровень: Ци должно стать свободным, и даньтянь должен быть отрезан от канала нади который держит его в одном месте, для подготовки к следующему уровню. И наконец четвертый уровень: две энергии должны быть соединены.
Джим Макмиллан - В поисках мастера Мо Пай (стр. 72)
Отрывок из книги Джимма:
He explained to me, “Your yin comes from the earth and you need to be connected to it.” He said I have to sit outside on the ground. This was somewhat troubling because where I live it snows about twice a year and rains a lot, so while he was telling me this I was trying to figure how I was going to be able to do it. He also told me yang comes from the air and enters the energy point on the top of your head. And it needs to be equally balanced with my yin which enters another energy point at the area of your perineum.
McMillan, Jim - Seeking the Master of Mo Pai (p. 178).
Перевод:
Он (Джон Чанг) объяснил мне: "Твой инь приходит из земли и тебе необходимо быть подсоединенным к ней". Он сказал, я должен сидеть снаружи на земле. Это было немного проблематично, потому что там где я жил, шел снег примерно два раза в год и шло много дождя, поэтому пока он говорил мне это, я пытался придумать как я буду способен делать это. Он также сказал мне, что ян приходит из воздуха и входит в энергетическую точку на поверхности головы. И ян должно быть равно сбалансировано с моей инь, которая входит в другую энергетическую точку в области промежности.
Джим Макмиллан - В поисках мастера Мо Пай (стр. 178)
да интересно надо попробовать.
а Вы сами не пробовали?
EvoLogos
S1908 wrote: Fri Aug 17, 2018 7:23 pm да интересно надо попробовать.
Я ощущаю пульсацию в своем нижнем дяньтяне, даже когда немножко сконцентрируюсь на нем. Он "взбрыкивается" время от времени. Я уже почти подготовился, вдохновившись другими участниками этого форума, которые тоже начали свои опыты в работе со своим энергетическим телом, чтобы начать заново и на серьезном уровне свои энергетические тренировки. Я напишу в этом топике в будущем, свои новые опыты, в моей работе с чакрами и даньтянями.
EvoLogos
Вычитал в этой книге. Интересненько...
Ли Ноу. Жизнь - эпическая история наших митохондрий, 2014 год / Lee Know. Life - The Epic Story of Our Mitochondria
Активные в метаболизме клетки, такие как сердце, мускулы и мозг, содержат в себе тысячи митохондрий. Женская яйцеклетка имеет ошеломляющие 100 000 митохондрий. В противоположность, сперматозоид содержит менее 100. Красная клетка крови и клетки кожи имеют очень мало митохондрий, или не имеют их вообще. По весу, до 10% человеческого тела приходится на митохондрии. В числах, их порядка десяти миллионов миллиардов в теле. Поговорка "сила в числе" выглядит вполне уместной.
Митохондрии эволюционировали быть электростанциями или энергетическими заводами внутри клеток.
EvoLogos
Еще демонстрации проекции энергии Ци, мастером цигуна, Цзяном Фэнгом (Jiang Feng).
У людей возникает ожог на коже.
EvoLogos
Mira Shards wrote: Wed Aug 15, 2018 8:38 pm 1. Исходное положение – встать прямо, расстояние между ступнями приблизительно 45 см.
2. Колени чуть согнуть, немного попружинить, чтобы расслабить их. Спина прямая.
3. Руки развести в сторону, образуя фигуру креста, пальцы рук поднять вверх, при этом ладони образуют прямой угол по отношению к рукам.
4. Закрыть глаза и стоять в этой позиции от 5 до 10 минут, отслеживая свои ощущения. Даже новичок ощущает, как энергия движется от кончиков пальцев, через руки в тело.
EvoLogos, как думаете, возможно рассматривать новичку данное упражнение, является ли оно правильным на ваш взгляд ? Интересно именно ваше мнение.
Я не знаю. Дело в том, что энергия Ци (ее также называют Чи или Ки), часть тонкого тела. У индийских йогов эту энергию называют праной. В китайском цигуне есть более подробное разделение энергий в тонком теле, таких как Цзин (jīng), Ци (Qi) и Шен (Shen). Так вот, в нормальном состоянии обычный человек не ощущает работу своего энергетического тела. Так что с моей точки зрения, это сомнительно, что человек-новичок начнет ощущать течение энергии Ци, просто лишь потому что он примет какую либо позу, и немного сконцентрируется. Он конечно может что-нибудь ощущать, но вряд ли это будет именно ощущение его энергии. Поэтому, я к примеру начал делать свои энергетические упражнения, после моей встречи с астрологами, которые произвели некоторые изменения в работе моего энергетического тела. Как сказал астролог, он сделал меня более развитыми. И после того, как у меня пробудились две верхние чакры, я жил с постоянным ощущением давления в них. Поэтому, когда я концентрировал внимание на них, и представлял как сквозь них проходит энергетический шарик, то мое давление в них усиливалось в разы, и я явно понимал и чувствовал, что то, что я делаю - это реально, и я испытываю реальные изменения в работе моего энергетического тела. Романтик, к примеру, сказал, что у него пробудились чакры после того, как он много медитировал, и у него тоже, постоянное давление в верхних чакрах. Этим он привлек мое внимание к себе. Я делал упражнения по модифицированной системе Роберта Брюса, под эпические видео на Ютубе, которые меня вдохновляли, а астрологи следили за моим прогрессом. Романтик тоже делал упражнения Роберта Брюса. Когда я начал во второй раз делать серьезно свои упражнения (после нападения джиннов, после того как я вышел из больницы), астрологи сказали моему другу обо мне - у него повышается. Вероятно они имели ввиду уровень энергии. Также, когда я ложился на кровать после еды, чтобы подымать Кундалини, я испытывал ощущения, как будто у меня в позвоночнике проходят молнии. Астрологи сказали обо мне, что у меня были очень хорошие результаты (Но это было в первый раз, до нападения джиннов). Но результаты мне испортили джинны, которые напали на меня, из-за которых я попал в больницу, и я на некоторое время прекратил свои упражнения. Но все это было еще в 2013-2014 годах.
Роберт Брюс говорит, что нужно начинать делать энергетические упражнения, желательно по его методу, и со временем, энергетическое тело начнет функционировать во все более и более мощном режиме, и чакры начнут ощущаться. Правда потом, когда энергетическое тело окрепнет, ощущения вновь ослабнут, так как энерго-тело станет привычным к работе с более мощными потоками энергии.
Любая физическая активность оказывает влияние на энергетическое тело, так что нужно просто стараться делать разные энергетические практики и стараться все время ощутить работу своего энергетического тела. Со временем это получится.
Мои упражнения, которые я делал - это пытаться поднять энергию через нижние чакры и протащить ее вверх к верхним чакрам. А также по пути стимулировать все чакры всеми доступными способами, которые сам изобретешь, лишь бы они работали хоть как-то, и были ощущаемы какие-либо изменения.
EvoLogos
Mira Shards wrote: Thu Aug 16, 2018 4:01 pm Эс, я так поняла, что активация чакры может привести не только к восстановительным процессам, но и к разрушительным...Есть обратка что ли? Вот мы с тобой не обсуждали это, для меня открытие 😮😮
Получается, что чакральную систему необходимо правильно развивать, прокачивать, именно так, чтобы не во вред здоровью.
99% процентов людей не Земле никак не прокачивают и не развивают свою чакральную систему, потому что банально не чувствуют чакр, и даже не верят в их существование. Свои энергетические тела развили такие мастера, как Роберт Брюс и Джон Чанг, поэтому лучше сперва ознакомиться с материалами и книгами о них, которые есть в сети. Эти люди - одни на миллиард. А другие люди, лишь говорят о чакрах, но мало кто достиг хоть чего-нибудь на деле.
Чакры активны у человека с рождения, и работают постоянно. Но если человек хочет открыть в себе экстрасенсорные способности, то ему нужно увеличить пропускную способность чакр и энергии которая проходит через них, через энергетические практики.
От того, что человек попробует например упражнения Роберта Брюса, по работе с чакрами, ему не будет никакого вреда. Энергетическое тело у человека обладает достаточной прочностью, чтобы от простой стимуляции, ему ничего не было. Чтобы был вред здоровью и чакральной системе - для этого нужно к примеру стать заядлым наркоманом, годами с десятью стажа, вот это действительно принесет вред.
А так, организм человека полностью автономный и через мозг постоянно саморегулируется, так что даже после начала энергетических практик, в организме человека будут происходить автоматические процессы урегулирования течения энергии в энерго-теле. Физическое тело и энергетическое тело, обладают своей мудростью, вплоть до клеточного уровня.
EvoLogos
S1908 wrote: Thu Aug 16, 2018 6:57 pm у обычного человека нижние сильные а верхние слабые и энергии надо подняться с нижних чтобы запустить верхние
Роберт Брюс учит наоборот, что у современного человека более активные верхние чакры, в силу того, что человек много времени проводит за телевизором и постоянно бомбардируется непрекращаемым потоком новостей. Он говорит, что в древние времена, у монахов, был более спокойный образ жизни, и у них были более гармоничные чакры.
Роберт говорит, поэтому современному человеку нужно уделить особое внимание стимулированию корневой чакры Муладхары.
S1908 wrote: Thu Aug 16, 2018 6:57 pm если это не исправить то человек может умереть. так например делают порчу, снижают энергию в какой-то чакре.
Я почитал магические сайты. Никто кто там якобы может сделать порчу, не имеет нормальных представлений о работе чакр, и там не встречаются люди, которые действительно обладали бы способностью снижать энергию в какой-либо чакре. Обычно их порчи, то чем они занимаются, это какая то фигня, с моей точки зрения, в духе: порча через яйцо и свечу, порча через произнесения заклинания в полнолуние, порча через разламывание иголки или свечи и т.д. В общем, дурят сами себе голову люди. Не могут ничего добиться в реальной жизни, поэтому тратят время разыгрывая из себя ведьм и колдунов. Ищут легких путей, а так не бывает. А самое главное, способность к обучению отсутствует напрочь. Не способны ничего понять из реальных знаний, научных, проверенных коллективом ученых.
S1908 wrote: Thu Aug 16, 2018 6:57 pm но бывает и минус например верхние подымутся за счет какойто нижней и в ней энергия упадет ниже нормы. и там появится заболевание на физике причем серьезное. если это не исправить то человек может умереть.
Никто ничего нигде не исправляет, большинство людей не признают существования чакр. И живы себе, вполне здоровы. Не слышал, чтобы доктор хоть раз сказал - "Пациент умер, потому что у него стало мало энергии в нижней чакре. Неправильное распределение энергии." Организм человека прекрасно регулирует сам себя в автоматическом режиме.
хотел бы поблагодарить автора этой темы за огромный труд! спасибо вам за то что делитесь такой редкий и интересной информацией. задаете практикам новые вехи для развития. и мне много чего подсказали куда развиваться дальше. огромное вам спасибо!
EvoLogos
S1908 wrote: Sat Aug 18, 2018 6:43 pm хотел бы поблагодарить автора этой темы за огромный труд! спасибо вам за то что делитесь такой редкий и интересной информацией. задаете практикам новые вехи для развития. и мне много чего подсказали куда развиваться дальше. огромное вам спасибо!
Очень рад, что вам информация оказалась полезной.))
EvoLogos
Попытка делания метафизики (черновик), версия 0.1
После того, как мы проснулись после сна в котором отсутствовали сновидения, мы обретаем вновь утраченное на ночь сознание. Все что мы видим перед нами - является полностью симуляцией, которая генерируется мозгом вместе с чакрой Сахасрарой. Все что находится в сознании - это виртуальная реальность. Сознание - это управляемая галлюцинация.
Сон является виртуальной симуляцией, а не является миром существующим самим по себе, и имеющим под собой объективную реальность. Доказательство этому служит к примеру то, что когда мы спим, и нам снится сон - нас можно разбудить, потормошив наше физическое тело. С другой стороны, мы не можем проснуться снова, когда мы уже проснулись, и оказаться в каком-то еще более реальном мире чем уже реальный. Когда мы проснулись - мы оказываемся в настоящей физической реальности, существующей объективно. Также, когда мы спим, то мы дышим, чтобы получать кислород, через красные клетки крови, которые распределяют его между нашими другими триллионами клеток из которых мы состоим через кровеносную систему. И затем наши митохондрии забирают себе электроны из кислорода, и генерируют нам химическую энергию, которой "дышат" наши клетки. Внутри сна к примеру, мы не дышим, так как сон, повторяю опять - является всего лишь виртуальной симуляцией реального мира нашим мозгом, когда он занимается ночью, во время сна, перестройкой своих синаптических и нейронных соединений, с целью оптимизацией памяти в нейронных связях. Оптимизация необходима, с целью усвоения жизненного опыта полученного в течении дня, для дальнейшего его применения в жизни в будущем. Во время сна происходит интеграция старых знаний с новыми, закодированных внутри нейронных соединений.
Когда мы проснулись, все что мы видим перед глазами - не существует таким, как нам это кажется, так как является лишь внутренней репрезентацией, упрощенной моделью мира в котором мы живем. Репрезентации и модели необходимы, чтобы попытаться отобразить упрощенно структуру мира в котором мы живем. Мир бесконечно сложный для понимания, в силу бесконечного количества процессов которые в нем происходят, и наш мозг просто не эволюционировал в достаточной мере, чтобы отображать все то богатство, что есть в физическом мире. Да это и не возможно в принципе.
Как учит современная физика, мир в реальности не трехмерный, а одиннадцати-мерный. Почему мы видим лишь три измерения? Ответ: потому что вообще все что мы видим, это виртуальная реальность, генерируемая нашим мозгом и чакрой Сахасрарой, и в виртуальной реальности у нас создается ошибочное представление, что мир трехмерен. Так как мы не способны осознавать бесконечную сложность нашего собственного физического тела - его клеточную структуру, биохимию клеток, молекулярный уровень, атомный уровень, субатомный уровень, струнный уровень и т.д., а также многочисленные скрытые измерения - то думаю, будет вполне верно применить метафору, и сказать, что мы живем "в тюрьме своего собственного неразвитого сознания".
Следующий вопрос, для размышления - а из чего состоит сон, и из чего состоит сознание, которое является виртуальной реальностью, симуляцией, управляемой галлюцинацией и служит для попытки упрощенной репрезентации, для создания моделей мира, которые бы отображали объективную структуру мира?
С точки зрения физикализма - философии утверждающей, что все можно объяснить в терминах физики, сами репрезентации мира в нашем сознании (все что мы видим когда проснулись), являются тоже состоящими из ультрамикроскопических струн, вибрирующими в одиннадцати мерном пространстве. Но не все согласны что сознание и сон состоит из физического материала, из струн и атомов.
Можно ли сказать, что раз мозг состоит из атомов, то и сон и сознание тоже, в конечном итоге, состоят из атомов? В философии эта позиция называется "теория идентичности" между мозгом, сознанием и репрезентациями сознания.
Бытует ошибочное мнение, что сон необходим, чтобы пополнить человеческую энергию. Это заблуждение. Сон необходим для консолидации памяти на молекулярном уровне, выработки протеинов в нейронах, для перестройки синаптических связей между нейронами мозга, чтобы опыт полученный во время дня, перешел из кратковременной памяти в долговременную. Большинство людей не представляют себе, что такое сон. Это очень сложный процесс.
Так что МИФ №1: мы спим чтобы пополнить растраченную за день энергию.
Правильный ответ: мы спим, чтобы в мозге консолидировалась память на молекулярном уровне, и перестраивались синаптические связи между нейронами.
-------------------------------------Старый материал-------------------------------------
Доказательство объективности мира, того, что у него имеется внутренняя структура, существующая не зависимо от человеческого сознания:
1) Компьютер работает по законам физики, которые открыты Западной цивилизацией, а не Восточной, где преобладал буддизм, следовательно даже когда мы не воспринимаем как текут электроны по проводам в компьютере, компьютер все равно работает и выполняет миллиарды математических операций в секунду. Следовательно это доказывает что имеется некоторая структура мира, и мир не рандомен, а управляется законами которые существуют независимо от восприятия сознательным существом.
2) Законы могут быть сформулированы в математические структуры. Физика описывает как мир ведет себя, подчиняясь физическим законам. Яблоко падает вниз а не вверх.
3) Некоторые современные физики выдвинули гипотезу, а может ли быть так, что физические законы, которые открыли Галилей, Ньютон, Эйнштейн и другие, не статические, а эволюционируют со временем, меняются, развиваются. И может быть вся Вселенная эволюционирует со временем.
Доказательство того, что мы живем в тюрьме своего собственного неразвитого сознания:
Роберт называет современную науку мусором - junk science, потому что ученые 100% уверенны что энергического тела и чакр нет, так как их не просто не видно глазом или они не чувствуются на ощупь, они даже не определяются ни одним устройством. Но они есть, а значит современная физика либо не полна - в лучшем случае, либо просто ошибочна. Я до этого читал Иммануила Канта с его идеей что мы видим не глазами а мозгом (например во сне мы видим, хоть физические глаза и закрыты), или даже более радикальной идеей что и мозга то нет а есть лишь его представление в нашем сознании, а какой мозг в реальности - мы не можем знать. Мы в тюрьме собственного слабо-развитого сознания. И лишь благодаря ясновидящим людям вроде Роберта, мы можем знать что есть невидимые чакры, есть астрал и т.д.
Почему люди, которые называют себя учеными и которые говорят что у них открытый разум и они готовы смотреть на факты, но с учетом рационального подхода и скептицизма - почему они считают что все что связано с чакрами - это выдумки? На мой взгляд, проблема в том, что они думают, что человеческое сознание видит мир как он есть. И наше сознание показывает все что есть, а если оно чего-то не показывает - значит этого нету. То есть человеку эволюция дала глаза, уши, нос и т.д. чтобы показывать то что есть, а если что-то не показывается - значит этого нет. И эта точка зрения ведет к заблуждению. У человека есть живое-биологическое-энергетическое тело, которое не воспринимается обычными органами чувств, а значит целью эволюции не было дать человеку глаза чтобы он видел мир полностью и знал что-то о себе. Эволюция позаботилась лишь минимально, чтобы человек нашел что съесть и оставил потомство. Т.е. если человека не учить в школе что у него есть мозг в голове, он никогда об этом сам не догадается. Точно также, если бы не некоторые люди обладающие ясновидческим зрением - мы бы никогда не узнали что у человека есть энергетическое тело и чакры, которые живые как и биологическое тело и которые могут расти со временем.
Хотя мы говорим нейроны в мозге обрабатывают новую информацию - в реальности же информацию обрабатывают молекулы из которых состоят нейроны. И даже не молекулы - это атомы, или микроскопическое струны которые еще меньше атомов, и в конечном итоге - само бытие проводит проработку события на каузальном уровне, и проводит вычисления. Вселенная вычисляет саму себя.
Вообще, это всего лишь предположение, что человек мыслит мозгом. Может быть к примеру, что человек мыслит чакрой Сахасрарой, которая является мозгом энергетического тела. Это не ясно, где происходит формирование ментальной жизни человека. Энергетическое тело вроде как питает физическое тело, так что вполне возможно, что без чакры Сахасрары у человека просто не будет сознания. Проблема в том, что чакры невидимы, и поэтому о них ничего не известно, поэтому тут остается лишь строить предположения. Возможно, что у Сахасрары тоже есть энергетические нейроны.
Представьте себе на минуточку, что все человечество на данный момент ошибается, когда предполагает что мысли у людей возникают в мозге, когда на самом деле они возникают в чакре Сахасраре. В энергетических нейронах чакры Сахасрары.
Может быть в будущем возникнет Интернет чакр, где чакры разных людей, будут соединены в единую нейросеть, где каждая чакра будет исполнять функцию одного нейрона.
Будет происходить обмен энергиями, и будет запущен процесс развития энергетических тел людей. Можно будет выращивать новые чакры, и обмениваться ими с другими людьми.
>> Мы живем в своем мире в абсолютном, тотальном смысле этого слова, где все внешнее это всего лишь наши образы-представления, не более того.
С одной стороны образы, но с другой стороны, образы нужны сознанию, чтобы помогать жить. Например, мы знаем что кирпич не существует таким как он нам кажется, потому что мы изучали в школе, что кирпич состоит из молекул, молекулы из атомов, а атомы из еще меньших частиц и энергии. Но сознание эволюционировало лишь до такой степени, чтобы показывать нам кирпич как кирпич. Тем не менее, когда мы идем по улице, и если вдруг нам не повезет, и кирпич упадет с крыши дома нам на голову, то он вмиг отшибет нам сознание и мы вырубимся. Следовательно кирпич существует независимо от нашего сознания, объективно. Кирпич не совсем существует как он нам кажется, потому что существует не кирпич а огромное количество атомов. Следовательно существование атомов собранных в кирпич объективно, а восприятие кирпича в виде кирпича субъективно. Кирпич существует объективно, а воспринимается субъективно. Хищник в фильме о хищнике, мог менять то как он видит людей разными способами благодаря своему устройству, может быть более развитое сознание может также менять свое восприятие и без устройства. Мир существует независимо от того, что мы думаем о нем и хотим. Например, мы не можем силой воли убрать чувство голода, и если мы не будем есть, в животе будет сосать и урчать все сильнее и сильнее. Поэтому, мы не боги, что творят свои миры, мы приспосабливаемся к миру и адаптируемся. По сути все то, что мы видим - это такая же галлюцинация, как и то, что мы видим во сне, с разницей лишь в том, что когда мы проснулись - имеется обратная связь между событиями в мире и нашей галлюцинацией, и когда кирпич начнет падать нам на голову, мы попытаемся отбежать в сторону. Никто еще не ответил на вопрос - из чего сделан сон? Из какого материала?
1. Мы не видим чакр, даньтяней, каналов нади, канды, главных каналов в тонком теле (Сушумна, Ида, Пингала). Не чувствуем энергию Ци, прану.
2. Мы не видим атомов, ультрамикроскопических струн.
3. Мы не видим одиннадцать измерений, в которых существует наш мир с математической точки зрения, с позиции современной физики
4. Мы не можем изменить свое восприятие мира, как например мог хищник в фильме 'Хищник', чтобы видеть мир например в инфракрасном спектре.
5. Мы не можем выключить сознание и включить его по желанию.
6. Мы не можем включить в сознании режим "Дополненной реальности", как например позволяют некоторые новые очки-устройства.
7. У нас отсутствуют органы чувств, которые бы показывали нам к примеру генетическую структуру нашего ДНК, или отображали биохимию внутри нашего тела и внутри наших клеток. Мы не чувствуем наш Микробиом.
8. Мы ничего не знаем о триллионах биохимических и эндокринных процессах и реакциях которые происходят каждую секунду в нашем теле.
9. Мы не можем видеть духов, джиннов.
10. У нас отсутствует удаленное зрение - ясновидение (Remote viewing, Clairvoyance).
11. У нас нет спиритуального видео-экрана (Vision Screen), который есть у астрологов и у Роберта Брюса.
12. Мы не можем перейти из состояния бодрствования в режим сна за секунду, и быстро переключаться между этими двумя репрезентациями мира.
Генетическая структура нашего ДНК
Биохимия внутри наших клеток
Микробиом
Микробиомом называют всех тех бактерий что живут внутри человека и на человеке.
Чакры
Поэтому, можно сказать, что у нас почти полностью отсутствует сознание. Сознание человека не развито, оно не эволюционировало достаточно.
Появление мозга - большое достижение в истории эволюции. Что может быть следующим большим шагом в эволюции, сравнимое с появлением мозга? Может быть как эдиакарский организм не мог себе представить что мозг возможен, так как у него просто не было мозга, а поэтому вероятно и сознания, точно также и мы не можем представить что будет следующим эволюционным развитием, сравнимым по значимости с появлением мозга?
Эдиакарский организм без мозга.
Эдиакарские животные (жили 635-532 миллионов лет назад) не имели мозга и цедили полезные вещества из воды. Они лежали на дне, и просто впитывали как губка все полезное.
Сколько чакр было у этого организма? Вероятно Сахасрары у него не было точно.))
Следующий орган в эволюции, более значимый чем мозг, чем он может быть? Настолько революционный, что он полностью изменит жизнь и бытие организма у которого появится через процесс эволюции.
Может быть у людей будущего, будет две чакры Сахасрары? Или десять? И одновременно они будут обладать десятью сознаниями сразу? Между которыми они смогут переключаться. Иметь одновременно десять виртуальных реальностей в одном теле. Идти по улице, и одновременно слушать любимую музыку, смотреть любимый фильм, читать любимую книгу, общаться с другом, и иметь шесть разных снов, в реальном времени.
По причине того, что контент сознания (все что мы видим когда проснулись) является его репрезентацией, мы не можем знать какими являются "на самом деле, в реальности" мозг и Сахасрара. Это парадокс, мозг с Сахасрарой генерируют сознание, и их собственные репрезентации (репрезентации их самих) попадают внутрь сознания. Т.е. сознание пытается найти источник самого себя. И следуя этой логики, репрезентация мозга находится внутри мозга. Все что мы видели в своей жизни - это все репрезентация сознания, которая генерируется мозгом (и вероятно Сахасрарой).
Повторю, для лучшего понимания: Все что мы видим - это не настоящее, а существует лишь внутри нашего сознания. Все что существует внутри нашего сознания - это модель мира, а не сам мир. Поэтому, когда мы что-то видим (не важно во сне или наяву) - это является симуляцией и виртуальной реальностью.
Существует радикальная идея, что и мозга то нет а есть лишь его представление в нашем сознании, а какой мозг в реальности - мы не можем знать. Это философский вопрос, может ли сознание в полной мере понять структуру, через которую оно возникает. С точки зрения физикализма - наш мозг является одиннадцати-мерным. А наше сознание и его репрезентации - эволюционировали лишь чтобы быть трехмерными. Так что может ли мозг понять сам себя в полной мере?
Теософ Анни Безант предлагала такую теорию сознания - что это противоположность материи, типа как инь и ян. Соответственно, чем проявленнее материя - тем проявленнее сознание и наоборот, как 2 стороны 1 монеты. Получается что сон - проявление слабой материальности от слабого сознания или наоборот. Следовательно ОС - проявление более сильного сознания в силу более сильной материальности сна.
EvoLogos
----------------------- Сердечная сутра (одна из самых популярных сутр в буддизме) -----------------------
Авалокита, Святой Владыка и Бодхисаттва, погрузился в глубокое течение Мудрости, вышедшей за пределы. Он взглянул с высоты и узрел лишь пять совокупностей, и увидел он, что в своем самобытии они были пусты.
Так, Шарипутра, форма есть пустота, а сама пустота есть форма; пустота не отличается от формы, форма не отличается от пустоты; что бы ни являлось формой, это пустота, что бы ни являлось пустотой, это форма; то же самое справедливо по отношению к ощущениям, восприятиям, импульсам и сознаниям.
Так, о Шарипутра, все дхармы отмечены пустотой, они не порождены и не прекращаются, не загрязнены и не безупречны, не ущербны и не совершенны.
Потому, Шарипутра, в пустоте нет формы, нет ощущения, нет восприятия, нет импульса, нет сознания. Нет глаза, нет уха, носа, языка, тела, ума. Нет форм, звуков, запахов, осязаемого или объектов ума. Нет элемента органов чувств и так далее, пока мы не доходим до того, что нет элемента сознания ума. Нет неведения, нет прекращения неведения и так далее, вплоть до того, что нет разложения и смерти и нет прекращения разложения и смерти. Нет страдания, нет возникновения, нет прекращения, нет пути. Нет постижения, нет достижения и нет не-достижения.
Потому, Шарипутра, именно благодаря такому безразличию к любого рода личным достижениям и вверению себя Совершенству Мудрости Бодхисаттва пребывает без завесы мыслей. Не прикрываясь мыслями, он не впадает в трепет, он преодолел все, что может его опечалить, и, в конце концов, он достигает Нирваны.
Я нашел сайт Джейравы (Jayarava), жителя Британии, переехавшего туда жить из Новой Зеландии.
Он позиционирует себя как буддиста. Он выучил китайский и пали, и теперь у себя в блоге проводит глубокий анализ сутры сердца, не только на английском но и на других языках. С интересом слежу за статьями этого филолога-ученого. Очень грамотный мужик.
Метафизика Сутры Сердца - это учение о Пустоте.
Для философского термина Пустота, есть специальный термин - Шуньята (Sunyata).
Определение Пустоты: все существующие вещи и объекты пусты в том смысле, что они не имеют присущего им определенного (структурного) существования и не имеют природы.
Сутра Сердца и память
Так как все что существует - это иллюзия, так как мир не имеет субстрата, то человеческая память тоже пустотна. То есть в реальности, у человека отсутствует память. А то что человек помнит - это память иллюзорных событий, так что это в такой же степени не реально, что с точки зрения буддизма, об этом с трудом можно даже сказать что это является "настоящей" памятью.
В сердечной сутре сказано, что то что воспринимают органы чувств, такие как глаза, уши, язык, нос и кожа через осязание - все это пустотно, а значит является иллюзией.
Все что человек видит перед собой, все что находится внутри его сознания - это все пустотно, а значит также является иллюзией.
Поэтому, Будда поняв природу пустоты, пришел к выводу, что все что мы видим, ощущаем, воспринимаем, и даже само сознание и его контент - все это иллюзия. В реальности, глаза, уши, нос, язык, тело и мышление - это тоже иллюзии, и не имеют какой-то реальности под собой. В мире не существует форм, звуков, запахов, осязаемого или объектов ума.
Но буддисты пошли легким путем, когда заявили что боль и страдание - это тоже иллюзия. Если у человека заболит живот или зуб, или он простудится - он не сможет убрать свои заболевания, лишь потому что он осознал, что мир пустотен. Просветление не дает магических способностей. Поэтому, существуют врачи и лекарства, которые действительно лечат, и избавляют от болезней и страдания.
Как работает биология с точки зрения буддизма? Что есть развитие и эволюция для сознательного создания с точки зрения буддизма?
Из Сутры Сердца следует, что любая цель которую человек ставит себе в жизни - не имеет смысла, так как всё пустотно и иллюзорно. Сказано: "Нет постижения, нет достижения и нет не-достижения." То есть стремиться особо не к чему, любые достижения в иллюзорном мире - тоже иллюзорны, и не считаются достижениями "взаправду".
Но с моей точки зрения, эволюция с точки зрения буддизма (мета-уровень) - это переход с менее реального уровня бытия и существования на более реальный. Эволюционировать, чтобы перейти с иллюзорного, пустотного уровня существования на более реальный уровень. Для этого нужно стать экспертом в области причинно-следственных связей. Чтобы самому стать причиной возникновения самого себя, а не чтобы случайные процессы послужили причиной возникновения тебя, твоей жизни и того что происходит в ней.
Размышление насчет буддийской Пустоты: все объекты не имеют структуры и какой-то определенной природы, потому что существует такое глобальное явление, как взаимозависимое происхождение (dependent origination). Буддизм не является физикой, а является скорее метафизикой. По причине того, что каждый существующий феномен, в каждый момент времени подвержен изменениям, так как на него влияет бесчисленное количество других феноменов, то с точки зрения буддизма, каждый феномен пустотен. Как сказал Гераклит: Все течет, все меняется. Нельзя войти дважды в одну и туже реку. И как сказали его последователи: Нельзя войти в одну и ту же реку даже один раз.
В буддизме также считается, что по причине взаимозависимого происхождения, у человека отсутствует самость.
(см. также список книг по буддизму, в этом посте).
С точки зрения небезизввестного ченнелинга 94 года - текущая цель человечества заключается в освоении-научении способностям согласно периоду расы, соответствующей чакре. Так, 4 раса соответствовала 4 чакре (по 7-ричной разбивке) и научилась любить. 5 раса включает все предыдущие способности и должна научиться "видеть душу, и не более".
5 чакра соответствует вишуддхе - ментальной материи и над вишуддхой (чакра затылка 18 лепестков) ментальной форме и образам.
6 раса - это видимо будет аджна - ментальное внимание - должна наступить в 2600 году. (Судя как развивается информационное пространство уже понятны задатки, из которых построится ментальное (информационное) внимание.)
7 раса - сахасрара - ментальный контроль.
(Выше над головой находятся буддхи чакры сочувствия и далее понимания.)
EvoLogos
AstralHacker wrote: Sun Aug 19, 2018 11:00 pm 6 раса - это видимо будет аджна - ментальное внимание - должна наступить в 2600 году. (Судя как развивается информационное пространство уже понятны задатки, из которых построится ментальное (информационное) внимание.)
Думаю, через 200 лет, когда клеточная биология, регенеративная медицина, достигнут невероятных высот и искусственная селекция вытеснит натуральный отбор, то уже к тому времени жизнь людей изменится радикально. Любовь и наслаждения тоже эволюционируют, как и всё. Станут ли они богоподобные, о чем сейчас невозможно даже представить? У кого какие мысли насчет футурологии? Человек является переходным видом, и рано или поздно, появится новый вид, как человек превосходит обезьяну, так и новый вид будет на таком же уровне превосходить человека.
Думаю, через двести лет, человек полностью совершит апгрейд своей биологической природы, и возможно сольется с машиной. Он будет жить на других планетах, и ему даже не понадобится космический корабль, чтобы туда попасть. Будет как супермен.
А вот мне даже страшно будет представить, какая будет через 200 лет экология...
EvoLogos
Александра - моя митохондрия №1.
Аня - моя митохондрия №2.
Амелия - моя митохондрия №3.
Диана - моя митохондрия №4.
Сегодня приснилась митохондрия №2.
EvoLogos
Ну что ж, думаю пришло время снова заняться своим энергетическим телом.
Когда ты прокачиваешь какую-либо одну чакру, то автоматически прокачиваются и все другие, так как в энергетическом теле всё взаимосвязано.
Так как я очень хорошо ощущаю существование своих двух верхних чакр - Аджны и Сахасрары - я постоянно ощущаю давление на переносице и на макушке (уже седьмой год), то мне очень легко делать энергетические упражнения. Я концентрируюсь на местах этого давления, и стараюсь надавить на это место еще сильнее, расшевелить это место и вызвать в местах давления еще более повышенную активность.
Приступил к прокачке Аджны и Сахасрары. Остальные чакры я не прокачиваю, так как не чувствую их. (Хотя я ощущаю, что в подпупочном центре что-то "взбрыкивается". И иногда я ощущаю пульсацию в солнечном сплетении, но я еще стараюсь получше "нащупать" это место.)
После стимуляции чакр, давление в них возрастает в разы.
Пока моя цель - поддерживать повышенную активность двух верхних чакр в течение длительного времени, через непрекращающуюся их стимуляцию.
Думаю, со временем я "нащупаю" все чакры в мое энерготеле, и смогу прокачивать их все.
Чувствовать чакры, чтобы более эффективно их стимулировать, это тоже навык, который вырабатывается со временем и практикой.
Я знаю, что моя прокачка не напрасна.
Во-первых, по сравнению с бактерией, я являюсь многоклеточным организмом, и по сравнению с ней являюсь существом более высокого эволюционного порядка. Так что, во время прокачки, в моем теле происходит колоссальное количество энергетических процессов, запускается процесс бесконечных изменений, направленных на развитие энерготела. Любая бактерия может мне лишь позавидовать. Я явлюсь целым космосом по сравнению с ней.
Во-вторых, прокачка полезна в долгосрочной перспективе. Я недавно заходил на форум Роберта Брюса, он в своем недавнем посте, по прежнему поддерживает двумя руками за, идею прокачки энерготела. Так что его точка зрения, о необходимости прокачиваться, не поменялась за последнее время.
Буквально, цитата от Брюса: Energy work, stimulating the energy body and its Chakras, regularly, will also help.
Моя линия преемственности идет от двух астрологов - Манука и его ученика Мустафы, каждый из которых сделал мне апгрейд моего энергетического тела, за что я им безмерно благодарен.
Я думаю чакры прежде всего прокачиваются, и это безопаснее всех методов, функцией организма, которую они выполняют. Например, чтобы прокачивать свадхистхану - надо трахаться. Чтобы прокачивать аджну - рекомендуют задействовать краткосрочную память ментального внимания (какого цвета был прошедший столб, в каких штанах была прошедшая тётка и т.п.). Чтобы прокачивать сахасрару - надо решать умственные задачи по ментальному контролю.
Это как в спорте - чтобы прокачать определённые мышцы - надо заниматься определённой нагрузкой.
Чтобы прокачать ментальные чакры - надо заниматься определённой ментальной нагрузкой. Чтобы прокачивать астральную чакру анахату - нужно загружать её астральным чувством "любовь".
EvoLogos
Сегодня приснился Роберт Брюс. Мы с ним шли в какое-то место, где я должен был ему демонстрировать свои паранормальные способности (вроде телекинеза или левитации), обретенные мной благодаря моим энергетическим практикам. Я ему говорю: "Из всех сверхсуществ, обладающих огромными способностями, я хочу быть как доктор Манхэттен (см. пост об этом), потому что он самый сильный." Роберт мне отвечает: "Ну это да, конечно...". Тут я проснулся.
Затем через несколько часов, приснился опять Роберт Брюс. В этот раз, он раскладывал передо мной, какие-то игральные карты в две стопки, закрытой стороной. В середине карт были, что странно, какие-то отверстия. Роберт показал мне одну карту, на которой был он изображен молодым, но он не очень был похож сам на себя. Затем, когда он закончил расклад, я услышал и увидел появление моей знакомой девушки по колледжу - Вероники (симпатичная девушка), которая сказала в спешке, тонким шаловливым голосом, чтобы я достал любую карту. Я достал, она сказала что это фокус - она подложила запомненную ранее ей карту под нужную карту, так что я достал именно ту карту, что и требовалось. На карте было нарисованное изображение пары, занимающейся любовью, в позе по-собачьи. На лицах девушки и парня было выражение счастья и блаженства.
Затем, снился третий сон, где я прощался с каким-то человек, после того, как он сел в трамвай.
Вообще, Роберт Брюс мне снится уже не в первый раз.
Может быть в этот раз, он приснился мне из-за того, что последнее дело, что я сделал перед сном - это посмотрел его свежий, августовский ролик.
Роберт говорит, что обычный человек знает меньше 1% о спиритуальном мире "Большей Реальности", как он его называет. Он говорит, что сам он, знает наверно 10%, так как он исследовал астрал всю свою жизнь. Так что, существует целый мир, который еще только предстоит исследовать, и многие открытия предстоит совершить, и это хорошо, это дает мотивацию и вызывает интерес.
Само видео: Интервью с Робертом Брюсом, август, 2018.
EvoLogos
День второй. Продолжаю прокачивать Аджну и Сахасрару.
Для тех кто знает английский язык, интервью студента Джона Чанга, Джима Макмиллана
Часть первая
Часть вторая
Часть третья
Часть четвертая
Фотографии Джона Чанга
Джон Чанг и Джим Макмиллан (Джим умер в 2013 году, от рака)
Джон Чанг и Коста (держит руку на плече Джона). Коста Данаос - ученик Джона Чанга и автор книги 'Маг с Явы'.
Вопросы для размышления:
1. Имеют ли бактерии микроскопические аналоги чакр и даньтяней (хранилищ энергии)?
2. Есть ли связь между митохондриями (электростанциями внутри наших клеток) и энергией Ци?
3. Какой процесс происходит в одиннадцати-мерном пространстве, когда через медитацию, происходит аккумуляция энергии Ци в нижнем даньтяне?
4. Во время медитации, митохондрии должны быть активны внутри нейронов (внутри каждого нейрона живут тысячи митохондрий) и работать в усиленном режиме. Могут ли митохондрии чувствовать биополе мозга, и работать коллективно и упорядоченно, как единая система?
На четвертом уровне, в системе Мо Пай, происходит обрезания канала нади, который соединяет нижний даньтянь с энергетическим телом, и даньтянь начинает свободно перемещаться внутри энергетического тела. Практик учится перемещать в разные стороны свой нижний даньтянь.
Джон Чанг общается со своими умершими учителями - предшествующими ему грандмастерами системы Мо Пай, биологический дух-эмбрион которых пережил их биологическую смерть, благодаря даньтяням внутри которых завершен сплав двух разных энергий - энергии инь и янь. Сплав инь и янь в нижем даньтяне совершается на четвертом уровне по системе Мо Пай. Джон Чанг совершил соединений этих энергий у себя, лишь с третий попытки, и чуть было не потерял сознание. Сплавленный даньтянь дарует огромную энергетическую мощь его обладателю. И позволяет пережить физическую смерть. Всего в Мо Пай 72 уровня. Сам Джон Чанг находится на 22-ом уровне. Духи-предки, которые являются главой секты Мо Пай, энергетически развиты на невероятном уровне, и могут с легкостью отнять жизнь любого человека, если бы им это вдруг захотелось. Система Мо Пай развивает энергетически человека, и он переходит на другой уровень физического существования.
Эволюция происходит через развитие своей энергетики. На данный момент, я серьезно воспринимаю лишь таких мастеров как Роберт Брюс и Джон Чанг. На данный момент, настоящее бессмертие достигается лишь через энергетическое развитие, и возможно двумя путями - через поднятие Кундалини (как Роберт Брюс) или через систему Мо Пай (через сплав инь и янь в нижнем даньтяне). Обычные люди рождаются, тратят свое время впустую, и умирают, уходя навсегда в небытие. Достижение бессмертия должно быть одной из первых целей, которую нормальный здравомыслящий человек должен поставить себе. Все проходит, но результаты энергетического развития через энергетические практики остаются.
Роберт учит, что подняв Кундалини, человеку открываются дороги к следующему эволюционному развитию. Практик может начать путь Вознесенного Мастера, Ангелический путь и еще многие другие пути открываются в "Большей Реальности".
EvoLogos
Научный пост №1, на тему Биоэнергетика. Версия 0.1
Этот пост я буду в будущем редактировать и дополнять.
Человек состоит из клеток.
Клетка постоянно борется со вторым законом термодинамики - стремлением распасться, то есть умереть. Для поддержания жизни нужна энергия. Энергия в теле химическая, то есть для понимания работы жизни, нужно знать биохимию. И клеточную биологию. Вы например знаете что такое катализатор (это из биохимии)? Или рибосом (это из клеточной биологии)? Вся энергия приходит на Землю из Солнца. Затем растения через фотосинтез создают кислород, которым человек дышит. Когда человек дышит, его красные клетки крови разносят кислород по всему телу, распределяя его между триллионами клеток тела. Затем митохондрии, что живут внутри клеток, забирают себе электроны из кислорода, и начинают создавать "насос" протонов, производя молекулы АТФ. Через рибосомы проходит РНК, которая синтезирует протеины внутри клетки.
Когда человек ходит в туалет по большому и маленькому, это результат второго закона термодинамики. Это неизбежно, и даже Бог не сможет избежать этого. Хаос удаляется из тела.
Вся энергия приходит через Солнце. Энергия вокруг нас, в виде кислорода. Поэтому человек эволюционировал, чтобы иметь легкие, чтобы вдыхать кислород, кровеносную систему, чтобы распределять кислород в своем теле, в силу того, что человек является многоклеточным организмом. И митохондрии внутри клеток, чтобы генерировать клеточную "валюту" в виде АТФ. Человек не получает никакую энергию из вне, как любят говорить шарлатаны, когда они заявляет что человек получает энергию через космос. Человек получает энергию лишь теми способами, до которых он эволюционировал. Человек вряд ли получит энергию, если он всунет два пальца в розетку. Электроны нужны человеку, но почему он не может питаться электричеством через розетку? Потому что, человек биохимическое создание, и электроны нужны для биохимических реакций. Он может извлечь от них пользу, лишь если будет получать их через натуральный для него способ, натуральный через эволюционный процесс, к которому он адаптирован.
Для себя не вижу смысла, в любой эзотерической литературе, так как она не дает мне ничего, и я не могу принять всерьез те выводы, которые в ней есть. Учебник по биохимии - вот выбор мастеров.
Приступил к перечитыванию моих любимых 800-страничных учебников по биохимии и клеточной биологии.
Без знаний биохимии, клеточной биологии и эволюции, человек не имеет никаких шансов, прокачать свои чакры, так как он не будет просто понимать что он делает, зачем он это делает, и какие результаты будут в результате.
Думаю мои любимые митохондрии (№1, №2, №3 и №4) оценят меня по достоинству, когда придет время.
Сегодня зачитал корифея от научного мира:
Пол Фальковски. Двигатели Жизни - Как микробы сделали Землю способной содержать жизнь, 2015 год / Paul Falkowski. Life's Engines - How Microbes Made Earth Habitable
AstralHacker wrote: Sun Aug 19, 2018 11:00 pm С точки зрения небезизввестного ченнелинга 94 года - текущая цель человечества заключается в освоении-научении способностям согласно периоду расы, соответствующей чакре. Так, 4 раса соответствовала 4 чакре (по 7-ричной разбивке) и научилась любить. 5 раса включает все предыдущие способности и должна научиться "видеть душу, и не более".
можешь поделиться ссылкой?
кстати astralhacker ты же поднимал кундалини? достиг какихнибудь способностей или вех для развития?
S1908 wrote: Wed Aug 22, 2018 12:11 pm
Ссылка на ченнелинг:
http://masterkosta.com/Files/Volgograd_ ... 00_str.doc
Кундалини - это всего лишь 1 из множества вариантов инь-компоненты. Инь-компонента даёт более материалистичное чувствование по всем чакрам, ян-компонента - осознанность. Главное в увеличении инь-компоненты - это найти на неё ян-компоненту для баланса, иначе происходит больше вреда телу, нежели пользы. Не обязательно использовать муладхару-чакру как источник энергии инь. Вообще мне кажется в нашу эпоху даже не нужно заботится об инь-увеличении, главный дефецит - это как раз ян-компонент - золотой ключик по сказке Буратино для входа в фазу. А главный секрет, чтобы вся связка работала - нужно собрать 3 компоненты вместе - инь, ян, дэн (средняя инь-ян). Когда рисуют человечка с сердечной только чакрой - это как раз показывают внутренний дэн-компонент. Эксперимент с янтрами показывает, что как раз ощущается нехватка в ян-компоненте, так как лучше всего работает янтра с излучением в золотом спектре, задействуя его как ян-компонент (проволока 0,21 мм - ожидается проверка). Инь-перебор в голове мешается очень контрастными мыслями и эмоциями, помогает его разбавка медитацией на небо - 1 из главных внешних поставщиков ян (или еще хороший ян-компонент - белый свет, уменьшенное солнышко рядом, ум струной/тонкий луч) - и в астрал после чего легко выходится. Мне кажется алхимики в средневековье как раз пытались получить золото как недостающий ян-компонент. В физическом выражении - кундалини - простое на-пря-же-ни-е. Например у Радуги есть техника напряжение мозга - это и есть "окундалинивание мозга".
огромное спасибо!
не знаю что там с кундалини но у меня последнее время позвоночник начал буквально гореть как будто там костер разжигают :)
EvoLogos
AstralHacker wrote: Wed Aug 22, 2018 12:50 pm Кундалини - это всего лишь 1 из множества вариантов инь-компоненты. Инь-компонента даёт более материалистичное чувствование по всем чакрам, ян-компонента - осознанность.
Чушь. Хакер сам себе голову морочит, не понимая о чем он говорит.
Вам необходимо перечитать пост Роберта Брюса:
Некоторые описанные здесь идеи, касающиеся Кундалини, могут отличаться от тех, что бытуют в традиционных
восточных практиках и школах философской мысли. Причина в том, что мои
размышления и методики основаны большей частью на моем личном опыте.
Кундалини – восточный термин, описывающий эволюционный
энергетический механизм
, встроенный в каждого независимо от цвета кожи,
вероисповедания и духовных традиций. Когда этот механизм активизируется,
говорят, что у человека проснулась Кундалини или поднялась Кундалини. В
современном западном мире к традиционному значению слова Кундалини очень часто
добавляют не слишком характерные для него описания очень тонких и нежных
энергетических ощущений. В таком смысле каждый, кто ощущает движения энергии,
выполняя упражнения из этой книги, может сказать, что он пробудил Кундалини. В
любом случае активация Кундалини в ее традиционном смысле – естественное
явление, всегда идущее рука об руку с духовной эволюцией и развитием
энергетического тела. Хотя пробуждение Кундалини не является специальной целью
этой книги, описанные в ней методы работы с энергией у некоторых людей могут
вызвать подобную энергетическую активность. Этого не следует бояться, к тому же
полностью избежать этого не удастся. Кундалини – своего рода энергетическое
семя, посеянное в основании позвоночника в области крестца. Восточная традиция
описывает ее как маленькую кобру, свернувшуюся в три с половиной оборота в
самом крестце. Разбудить ее можно с помощью духовной практики, работы с
энергией и интеллектуальной деятельности. Когда это происходит, говорят, что
Кундалини поднимается. Кундалини является квинтэссенцией духовной эволюции.
Будучи пробужденной, Кундалини дает мощный толчок в развитии личности человека,
его сознания как в духовном, так и в энергетическом смысле, а также усиливает его
духовную чувствительность и экстрасенсорные способности. Согласно традиции,
когда происходит спонтанный подъем Кундалини, в первую очередь это вызывает
ощущение шипов. Обычно это сильные и часто болезненно-жгучие, похожие на
электрические разряды прострелы снизу поясницы. Не путайте их с ощущением
адреналиноподобной энергетической волны через тело. Такие ощущения характерны
для обычной энергетической работы и определенного типа эмоциональной реакции. Полный
спонтанный подъем Кундалини – явление чрезвычайно редкое, и не стоит об этом
особо волноваться. Обычно, чтобы ощутить явные признаки пробуждения Кундалини,
уходят годы ментальной подготовки, энергетической работы, интеллектуальной и
духовной практики. (Кстати, известный швейцарский психиатр и основатель
аналитической психологии Карл Густав Юнг утверждал, что однажды испытал
спонтанный подъем Кундалини. Он много писал о первичных энергоцентрах, или
основных чакрах, и, разумеется, о Кундалини.) поскольку термин Кундалини у нас
широко используется для описанияочень тонких и нежных ощущений энергии, то для
описания главного события необходим был новый термин. Под главным событием я
подразумеваю полный подъем Кундалини, который я впервые пережил в 1990 году.Я
назвал это событие Огненный Змей Урей. Урей – часть золотого головного убора
египетских богов, например Амона Ра, и фараонов, представляющая собой поднявшую
голову свернутую кобру, помещенную на короне как раз в области Третьего глаза.
Я думаю, этот знак отражает полностью поднятую Кундалини, поэтому выбор
очевиден. Намекать на подъем Кундалини также может и символ кадуцея с
обвившейся змеей, о котором я упоминал раньше. Процесс подъема Кундалини может
происходит по-разному. Иногда он происходит с каждым первичным центром по
отдельности, а иногда – одновременно. Сам процесс может длиться от считанных
минут до нескольких часов или даже лет. Такие различия обусловлены разным
состоянием энергетических тел людей, а также наличием у них энергетических
блоков и уровнем их духовного развития. Полный процесс подъема Урея Кундалини
начинается с сильных, похожих на разряды электрического тока, острых
энергетических прострелов вверх вдоль позвоночного столба. Далее происходит
прострел мощного столба энергии через центральный канал. После этого вы
чувствуете, как змеиная энергия поднимается по вашему телу. Ощущения такие,
словно реальная змея толщиной с запястье пробирается по телу от области
промежности вверх, через шею в голову, совершая при этом три с половиной
оборота по часовой стрелке вокруг центрального канала. Когда она достигает
головы, перед вашим мысленным взором вспыхивает яркий, ослепительно белый свет.
Это мощный строб межбровного центра.
Подъем змеи – очень глубинный процесс, и
время от времени он может вызывать ощутимое скручивание желудка. Это неприятно,
но не причиняет боли. Я думаю, такие эффекты происходят из-за внутреннего
змееподобного проявления эктоплазмы. (Эктоплазма – полутвердая эфирная
субстанция, которую вырабатывает энергетическое тело.) После этого вам может
показаться, что межбровный и макушечный центры временно отключились. Словно
ваши глаза и нос чем-то закрыли. Вообще, Кундалини описывают как кобру,
поскольку сопутствующие ощущения напоминают движение кобры. В ходе этого
события возникают и энергетические, и физические ощущения. Поэтому кобра – не
просто символ, но и наглядное описание процесса. Термин подъем Кундалини
немного вводит в заблуждение. Более наглядными будут слова: Кундалини
выпускается или высвобождается. Как только процесс начался, то уже очень трудно
или даже невозможно его остановить. Ранние ощущения бывают очень мощными и
довольно болезненными. И хотя они сохраняют свою интенсивность, болезненность
ощущений бывает только несколько первых раз. Следует уточнить, что событие
подъема Кундалини – не просто раз – и готово, при котором наступает мгновенное
просветление и проявляются всяческие экстрасенсорные способности. Во время
успешного подъема Кундалини человек действительно может достичь состояния
просветленного сознания, но это довольно кратковременное состояние. По окончании
этого процесса сознание вернется на привычный уровень. Тем не менее этот опыт,
безусловно, во многом изменит личность человека, поскольку у него произойдет
заметный рывок в процессе духовного развития. Слова просветление и озарение не
только очень точно характеризуют яркий свет в межбровном центре, но также
описывают и изменения во внутреннем взоре. На этом уровне духовного развития
перед вашим мысленным взглядом действительно возникает свет. То есть с
закрытыми глазами человек будет видеть свет, идущий сверху. Хотя с подъемом
Кундалини до макушечного центра происходит лишь временное просветление до
уровня абстрактного Божественного Сознания, это, тем не менее, весьма заметно
подталкивает ваши духовные, экстрасенсорные и интеллектуальные способности к
активному росту. Личности, побывавшие в подобной ситуации, начинают постепенно
обретать внутреннего гения. Однако как именно проявится этот гений – целиком
зависит от природных предрасположенностей человека. Одни могут стать гениями
музыки, другие – живописи или литературы, а третьи – гениальными учеными.
Вариантов масса – все зависит от природных наклонностей. Подъем Кундалини
приводит к новому уровню активности энергетического тела, который далеко не
ограничивается первичными центрами. Поднятую Кундалини необходимо развивать и
дальше. После самого первого высвобождения Кундалини будет развиваться с каждым
последующим событием Огненной змеи Урея. Кроме этого первого события также
могут возникать и другие явления, связанные с активностью Кундалини, например
эффекты Медузы и Аум-м-м. Эффект Медузы – мой термин, которым я пользуюсь для
описания явления Кундалини-Урея. При этом явлении кажется, что верхушки головы
нет и из поверхности мозга вверх тянутся сотни широких змееподобных антенн,
которые ощущаются как неотъемлемая его часть – так же, как пальцы – часть рук.
Ощущение это немного странное, но довольно приятное. Эти антенны формируют особые
геометрические узоры, которые, как мне кажется, связаны с тем, что традиционно
называют мандалами. Эти узоры отражают мысли, и как только мысли меняются –
сразу же меняется и форма узора. Некоторые из антенн будут указывать на объект
ваших мыслей, если он есть. Например, если вы подумаете о каком-то реальном
человеке, сформируется определенная мандала и некоторые из антенн укажут туда,
где сейчас находится этот человек. Эффект Аум-м-м – мой термин еще для одного
явления. Оно может начаться одновременно с эффектом Медузы, а может и после
него. Оно ощущается как глубокий, чистый звук Аум-м-м, вибрирующий внутри и
вокруг вас. Это непрерывный устойчивый звук, похожий на такой, словно множество
взрослых мужчин поют внутри пещеры гортанный звук Аум-м-м и из-за эха он
сливается в одну целостную вибрацию. Должен предупредить вас еще об одной вещи,
связанной с подъемом Кундалини. Это сильное и продолжительное сексуальное
возбуждение. Вероятность такой проблемы чрезвычайно мала, и вам не стоит об
этом беспокоиться. За всю свою практику мне приходилось сталкиваться с
подобными проблемами совсем немного раз, и только два случая были более или
менее серьезными. Вообще, все самые распространенные трудности, связанные с
возникающим во время энергетической работы сексуальным возбуждением,
незначительны и всегда носят временный характер. Разумеется, если вы
прислушиваетесь к голосу разума и следуете золотому правилу работы с энергией.
Кундалини полностью трансформировало энергетическое тело Роберта Брюса, многочисленные зарисовки которого, я неоднократно приводил в этом топике. У него выросло много новых дяньтяней.
Как можно видеть с этого рисунка, у Роберта не три дяньтяня (энергетических центров хранилища энергии) как у любого обычного человека, а 16.
А тут их количество увеличилось до 32.
А мелкие шарики - это чакры.
На самом деле, Роберт поднял Кундалини 7777 раз, он просто скромен, и пытается донести до людей некоторую мысль и развенчать миф, что она, Кундалини, поднимает лишь один раз и все. Этого якобы достаточно. Так думают люди, которые не представляют и не понимают такие понятия как эволюция, эмбриология, развитие, энергетическое тело и не могут соединить эти идеи у себя в голове. Чтобы осознать, началу какого процесса кладет пробуждение Кундалини и ее первое поднятие. Энергетическое тело неразвитого человека, является неразвитыми эмбрионом. А Роберт - это не эмбрион - это Арнольд Шварценеггер. У Роберта Кундалини поднята постоянно, просто в ней в разное время, разная энергетическая активность. И Роберт, чтобы не утруждать себя долгими объяснениями, старается упростить понимание слушателей, и просто говорит, что поднял ее 70 раз. Кундалини запускает развитие энергетического тела. Так чтобы оно развивалось, ее, Кундалини, нужно подымать через каждые несколько дней. А можно и вообще каждый день, как старался я.
Вот мой пост, описывающий то, как Кундалини работает:
Также, Романтик, уверен ли ты 100% что у тебя пробудилась Кундалини? Может быть у тебя началось развитие энергетического тела, но Кундалини еще не пробудилась? Делал ли ты упражнения по стимуляции самой нижней чакры? Были ли у тебя стробы - где происходили выбросы энергии, с одной чакры к другой, где она пульсировала некоторое время, накапливала заряд, а затем передавала его к следующей, вышестоящей чакре? Хотя с другой стороны, если у тебя сильная активность во всех чакрах по всему телу, может быть Кундалини у тебя не только пробудилась, но и поднялась, и вообще это вошло у нее в привычку? Привычку подниматься и стимулировать все твое энергетическое тело, ползая в нем, и проходя сквозь разные чакры и заряжая их повышенной энергией? Ты мог бы обратиться к бывшей жене Роберта Брюса, чтобы она тебя посмотрела с помощью ясновидческого зрения. Она женщина хорошая, добрая, и очень опытная по вопросу чакр и Кундалини. Она может сказать что происходит с твоим энергетическим телом.
Это руки Роберта Брюса. Шарики - это мини даньтяни, которые выросли. Проще говоря, на ладонях Роберта Брюса находятся энергетические шары, наполненные энергией. Они вращаются. Обратите внимание, что как присутствуют довольно крупные мини-даньтяни, так и маленькие - сателлиты-спутники. Они соединены каналами нади, которые тоже выросли. И все это появилось у Роберта Брюса благодаря тому, что он много раз поднимал Кундалини. Его энергетическое тело трансформировано и преобразовано.
Тут показаны разные стадии развития ладоней Роберта Брюса. Динамика вырастания новых каналов нади, и появление энергетических мини сателлитов-спутников. Все это постоянно усложняется и растет. Кундалини запустило эволюцию энергетического тела Роберта Брюса.
У меня такое ощущение, что читатели моего топика, не способны понять, то что в нем написано, и после прочтения, через пять минут у них все выпадает из головы. И им надо повторять все снова и снова.
Re: Как дела у Романтика?
Всё в мире делимо на инь и ян (и еще среднюю - дэн). Вышеприведенный пост описывает кундалини с точки зрения эволюции, а я описываю - с точки зрения инь-ян. Эволюционный принцип кундалини не противоречит тому, что - это - инь-энергия. А так как в мире всё делимо на инь и ян, то кундалини - не последняя и не первая инь энергия. Просто инь энергия (а именно - ядра Земли, огненных змеев), которую можно приспособить для эволюции по Роберту Брюсу и Йоге, а в частности - для активизации чакр.
По моим наблюдениям - инь-энергию кундалини для активации чакр можно заменять другой инь-энергией - например энергией Луны, энергией замкнутого пространства (пещерой, зеркалом Козырева, камерой Райха, бочкой Нострадамуса), магнитом, камнем - вон сколько инь-аккумуляторов, и чакры от них тоже активизируются. Но опять же - надо помнить и про инь-ян баланс.
EvoLogos
Unread post by EvoLogos »
AstralHacker wrote: Wed Aug 22, 2018 8:04 pm Всё в мире делимо на инь и ян (и еще среднюю - дэн). Вышеприведенный пост описывает кундалини с точки зрения эволюции, а я описываю - с точки зрения инь-ян. Эволюционный принцип кундалини не противоречит тому, что - это - инь-энергия. А так как в мире всё делимо на инь и ян, то кундалини - не последняя и не первая инь энергия. Просто инь энергия (а именно - ядра Земли, огненных змеев), которую можно приспособить для эволюции по Роберту Брюсу и Йоге, а в частности - для активизации чакр.
Деление мира на Инь и Ян - это религиозная китайская философия из Даосизма. В западной цивилизации, никто не воспринимает это деление серьезно. Если вы почитает современный учебник по физике - вы там точно не найдете религиозных понятий Инь и Ян. Атом состоит из электронов-оболочки и ядра состоящего из протонов и нейтронов. Принадлежат ли электроны к энергии Инь? Принадлежит ли ядро атома к энергии Ян? И что думал Эйнштейн, когда совершал одну революцию за другой в физике, был ли он под влиянием китайского даосизма? Может быть нет, а почему? А потому наверно, что с его точки зрения, деление мира на Инь и Ян - это донаучные представления о мире, которые может быть и были полезны в Китае две тысячи лет назад, когда науки еще не существовало, а сейчас это деление бесполезно, и не может дать никакого глубокого инсайта о природе реальности.
Роберт Брюс нигде также не употребляет в своих работах термины Инь и Ян, вероятно потому что не видит в них смысла.
Джон Чанг, китаец по происхождению, поэтому он в своем учении, использует концепты Инь и Ян, но и то, лишь условно. И надо понимать, что никто пока еще не знает, чем является энергия Ци, так как в настоящий момент, все что связано с тонким-энергетическим телом находится еще в донаучном периоде.
Лично для меня было важнейшим шагом в эзотерическом познании, что для активации чакр кундалини не стоит особняком, а является лишь 1 из путей, веточек, как и много веточек есть в спорте для поддержания здоровой физической формы, или вариантов боевых искусств.
Кундалини-йога является детенышем тантра-йоги, или её узкой направленностью только по части кундалини. Тантра же - священейшее учение об энергетическом (а не просто философском!) взаимодействие инь, ян и дэн. Например гухъясамаджа-тантра является практикой открытия чакр только представлением вокруг себя компонентов инь, ян и дэн. А когда они физические (буддийские ваджр и дильба) - то эффект еще сильнее. Я сейчас занимаюсь с разработкой янтры в физическом исполнении и меня радует энергетический результат, скоро опубликую в законченном виде.
Вообще слово ТРА - как мне открылось означает энергетическое взаимодествие инь, ян и дэн. ТАН-ТРА - учение или комплексная энергетическая практика с взаимодействием инь, ян, дэн. ЯН-ТРА - устройство-излучатель, основанное на взаимодействие инь, ян, дэн. МАН-ТРА - взаимодействие энергии через звуковую комбинацию инь, ян, дэн.
В тантризме разные энергии инь, ян, дэн назвали богами, и различают их - например бог Шива (чем не конкурент Кундалини?)
В западном мире упростили такой "высший пилотаж" - имена разным энергиям, и остановились на общих понятиях инь, ян, дэн, просто выделив некоторые вещи в эти 3 группы.
Упрощение тантризма до неразличения имен богов энергий инь, ян, дэн - стало для западного человека учением "НЕОТАНТРИЗМ".
Западный же "быдло" якобы разоблачает неотантризм, что это повод или прикрытие или оправдание того, чтобы только лишь уталять свою сексуальную энергию, не казаться развратником-трахуном, натягивая на себя уважительное слово восточной духовности - неотантрик.
